can you paint shocks without it peeling off?
1 reading
5K views 17 replies 12 participants last post by  blastersfaster7
#1 ·
i just picked these up off a good man on here for $40
is there any way i could paint the coils?
thanks
-mokas-
#3 ·
powder coating works best, but costs $$$
#4 ·
are you shure the power coating wouldent chip?
thanks
#7 ·
Powder coating doesn't cheap anywhere near as easy as paint. Powdercoating is baked on, not sprayed on. The easiest way to put them is to take the adjuster nut off and slip the coils off, then paint them with some hardcore paint, or get them powdercoated.
#9 ·
yamadjs08 said:
I wouldnt go through all the trouble of painting them, just get some shock covers for them, there are so many different designs and stuff :tup: O and let us know how you like them once you get them all set up and stuff. Im really thinking about getting a set :tup:
you cant beat it for 40, ill be shure to post a report :tup:
#11 ·
Hey, by the way, what shocks are those? Off what bike? I am thinkin of upgrading the shocks on my blasty but i don't want to pay $300 for a set. Do other shocks off other bike work alot better than the stock blasty ones? Thanks A Lot!
#12 ·
ya they work better for the price
the ones pictured are my banshee shocks
you can also use 250/z400/kfx400/400ex rears with a little modification :tup:
#13 ·
Ok thanks, i'll check on ebay for some nice ones...
#14 ·
thanks
-mokas-
Yes you can paint these coils but you will need some type of flexible paint, maybe an epoxy. regular paint and powder coats harden and do not flex, they chip off instead. Dont waste your money on the powder coat. One thing you might try is going to the local hardware store and buying some tool handle coating. You can get it in many different colors and it definitly will flex because its a rubber coating. GOOD LUCK!!!
#15 ·
ive painted coil and holds up great. Never a chip or peel so far in 2 years. Use good automotive paint in a spray gun with flex additive :tup:
#18 ·
i thought it was magneticly charged pant that is sprayed on then backed and repeted
