Struggling with this one, usually I can figure them out, but owner let it sit for a couple years, now it will start, but bogs and dies, like its running out of fuel. I took the carb apart, all the jets looked clean, but blew out all the holes and jets and made sure no problems, put it back together and after a few kicks with the choke on it starts, idles high, turn the choke off, hit the throttle a few times seems normal, then bogs and dies like it runs out of fuel...
Ive pulled the carb twice, the floats are working, everything is clean, Im stumped.. Thoughts?
Discussion Starter · #2 ·
Replaced the gasket inside the carb that goes under the jet block, that helped, but it still has no low enough power, and has a nasty bog. I have played with the needle, up and down and no position fixes it. Anyone have any other ideas? Im kind of stumped
