1 - 14 of 14 Posts
2004 yamaha warrior 350 partout
call or text 318 469 0628 (easiest way to reach me) DO NOT pm me. i havent posted enough to reply back.
everything is in great condition, nothing is torn up or in horrible condition and most or all parts will work on 1987 - present models. also some parts work on yamaha blasters.
all parts are to be shipped at your cost. also if you want local pickup i am located in shreveport la
$ Part
125 frame
100 tires and wheels
50 front wheel brake hubs (2)
20 brand new in package tusk top end gasket set
50 seat
150 plastics
20 brake light and assembly
25 start/stop/light switches
35 headlights and assembly
25 each whichever a arm you need
275 good running bottom end
200 complete non running engine (NEEDS ROD BEARINGS)
35 chain
20 shifter
25 left foot peg
25 right foot peg
25 ignition coil
75 carburetor
100 rear end (axle and all)
25 tie rods
25 gas tank
15 brake pedal
35 rear grab bar
50 brake lines and master cylinder
25 reverse knob and assembly
25 dash plastic with neutral and reverse lights
25 throttle assembly
25 each front shocks
25 rear shock
100 brand new battery non maintenance
25 front bake calipers
35 voltage regulator
35 swingarm
30 ignition switch with key
25 handle bars
20 steering stem
20 steering stem bushing
20 brake lever left
20 brake lever right
1 - 14 of 14 Posts
