1 - 11 of 11 Posts
say if i ordered a wr crank setup from my local dealer,
what is everything i need for it,
crank, rod, piston i know for sure,
does this come with a wrist pin , rings,
or do i need to order them aswell.
thanks
PM BansheeBC. He's a Yamaha dealer and he told me 355 for everything you need. He said that included gaskets and everything.
I bought the Kit from BansheeBC, it had everything I needed. All in all it had the pistion, rings, crank, left side cover seal, right side cover seal, clutch cover seal, wrist pins for piston, and the Yamabond gasket sealer. I might have forgotten something but you get the point. It had everything.
J
thanks, i live in canada so i was thinking shipping might be an issue due to the weight, does anyone know approx what that package from bansheebc weighs so i can at least get an idea what the shipping costs will be,
Bob ships all over the world.
Its my understanding you dont want a yz piston, unless you add a spacer.
Its my understanding the WR and YZ piston have a diffrent wristpin location. Thats what makes Bobs deal so sweet. Just drop in and go.
These are not Yamaha factory trained specs, just what i have learned.
pro450 said:
i would use a cp piston from ron woods you will need to buy a yz dirt bike piston $268
You can't use CP piston with WR crank they are diff.
only YZ or WR (same piston) with WR Crank, and should be from 2004 model
I'm using WR crank with YZ490 big bore kit.
That is correct you can use a CP,wiseco or whoever makes pistons, just make sure its for a yz/wr dirtbike with 18mm wrist pin, and your good to go, i just supply the factory piston because its most of the time what people want, 12.5:1 compression, and there inexpensive, so its coo, package only weighs about 9 pounds i would say, and shipping to canada is not a problem, i can use ups or post office, just takes a little longer with the post office
thanks
1 - 11 of 11 Posts
