Just purchased warrior 350 runs fine but wont electric start. Bought a new starter tested it and it's fine. I have 8.5 vdc coming from relay when start button pressed to starter but starter will not turn over installed. Any ideas??
not nearly enough voltage you have a bad or discharged battery also test the rectifier and stator to make sure make sure they are charging the battery. resting voltage on the battery need to be at or just over 12 and 13.5 to 13.8 running.
