Hello
I have a 2004 with a weak smoking motor. Will a 1999 model year engine be a direct replacement ?
Thanks
Strikefalcon
my best guess based on the info from the recyclers i use the cases are the same from 95 to 2005 so those should be a bolt in. ask for lots of pictures and be prepared to need to swap things like the electrical system, flywheel and carb as those changed often.
