Both the tires on my Rap (stock) wobble...The lock nuts for the hubs do not go tight enough to get the cotter pin to the next position...And my hub move a small amount. Would the cause the "wobble" in my tires or do you think I might have a bent axel...My bearings are fine, just replaced them.
If you dont think its the axel, how would this problem, if you think it is a problem, be resolved?
After years of pressure my carter pin holes don't line up either. I now have to tighten the sh*t out of the bolt to get it close. Go tight not loose!! Get another washer and it will help the hole line up.
I bought new rims and my tire wobble was gone completly. Not as much high speed vibration now either. Tire slime can also cause tire wobble.
