I am pretty sure the hub pattern on the polairs is different than on the warrior because the warrior hub pattern is 4/115 and the Polaris is 4/4" so the rims won't bolt up you would have to dismount the tires and put them on some 10" rims with a 4/115 hub unless you have a honda rear hubs on your warrior then you would need 4/110
