1 - 9 of 9 Posts
Got a prob, I can't figure out..... My warrior will only start by push start (pop clutch) I took the plug out and it has lots of blue spark with the start button, but won't start when put the plug back in... Even tryed to put gas in the cylinder and still no go.
Test the stator..
I went out to my warrior yesterday and it wouldnt start as well. Pressed the button to start it and nothing. I checked the battery and had full charge.
I jumped the solenoid with a wire to see if it was bad or if it was my starter... Fired right up. So I will be ordering a new one b4 its riding season.
To jump the solenoid; look at solenoid right above the rear left tire. There are 2 nuts on top of the solenoid, take a single wire and touch both ends to the nuts/wires, jumping the solenoid. Mine started right up when i touched them.
I had the same thing happen to me and it was the pickup coil if you get an aftermarket coil you might half to switch the wires around to make it run sometimes the come wired backwards.
1 - 9 of 9 Posts
