1 - 8 of 8 Posts
Hey guys, just recently, when I get up into a low through medium throttle wheelie, it starts to bog. If I press the gas, it just wants to die and it sounds like it is gurguling. It can do full throttle wheelies when the RPM's are up, but nothing like a slow wheelie that I can do tricks on. It just started doing this..... what could it be, the floats? Thanx in advanced!
The weather change could have messed with jets maybe?? I dunno. Clean your carbs out too.
try lowering the clip one cotch on your needle
it might work, but if it is the needle being too low then it might not even pull wheelies
Discussion Starter · #6 ·
I have done that.... It must be the float level cause my carbs leak and the drainage screws on the bottom of the float bowls are completely closed and they leak anyways :shrug:
1 - 8 of 8 Posts
