1 - 12 of 12 Posts
Hey, Can anyone give me a guesstimate on top speed on my R. ( Check the Sig ) Tire Size is a little bigger than 20-10-Somethin Ii cant get to the tire because theres about 16 stacked. Basicly a lil bigger than stock tires.
Thanks
You should be somewhere around 65-70 mph.
The trail tech computer you're talking about is the speedometer, right? It can be used on anything. Basically, you mount a magnet on a wheel or the brake rotor, and then mount a pickup to read it. Every time the wheel goes around, the pickup will sense the magnet. Basically, the computer is counting how fast the wheel is going around, and then uses the tire size to determine the speed. You have to dial it in for your tire size.
what i was going to say...i know a stock tecate was said to be at about 74-75 according to dirt wheels in the 80's...mine slightly modded tecate before it seized ran at 72mph...pretty damn fast IMO, and i never rode a 250r but from what i know the tecate was faster.
Thanks
go here http://home.earthlink.net/~gellett/250r.htm
just punch in your sprocket sizes along with tire size and you'll have your answer :tup:
If you can swap the front & rear sprockets you can do 600MPH :wtf: :scared: :razz:
wilkin250r said:
Not quite. It's not just a matter of rev limit and gearing, you still have this pesky little problem of "air resistance" to overcome.
air resistance?!
we don need no steenkin air resistance!
1 - 12 of 12 Posts
