Hey all... New here. I picked up a warrior for dirt cheap because the motor is blown up. I bought all the replacement parts but the crankcase i have doesn't look too good inside. The piston grenaded and took out a chunk of aluminum inside the case. What exactly does this little passage do? It's directly behind the oil pump. I'm having a hell of a time finding a used case for cheap. Plenty of other models, but ones for the warrior are high dollar ($250+). There are also plenty of right side case halves for the warrior. I'm assuming all the left halves bit the dust due to a chain failure?
Anyhow, hello, and who knows about these crankcases?
The damage can be seen below where the crankshaft goes.
6300
Ive owned one of these 350s for years. Mustve had a total of 2 oil changes in its life to nuke itself. There are ATV junkyards around the country that might be able to find you a crankcase. My service manual is at my house and ill be back tomorrow if no one can find out what that galley is about.
Best of luck
//Michael
