1 - 16 of 16 Posts
The a arms won't work....but A LOT of other stuff will. I'm too lazy to write all of them down. Here's a few: front shocks, sprocket hub, footpegs....
What parts will fit on the Yamaha Blaster,from other quads?
Yamaha Banshee Front Shocks
Yamaha Warrior Front Shocks
Honda TRX250R Rear Shock
Suzuki Quadracer LT250R Front Shocks
All Yamaha On/Off Switch
Yamaha Banshee Axle
Yamaha Banshee Wheel Hubs
Yamaha Banshee Brake Disc
Yamaha Banshee Gas Cap
Yamaha Banshee Bar Clamp
Yamaha Banshee Throttle Cap
Yamaha Banshee Carb.
Yamaha Breeze Air Filter
Yamaha Tri-Z Rear Rims
All Yamaha Key Modules
Honda Tail Light Bulb
All Yamaha Rod Ends
hmm, i knew it had 2 carbs and bigger quad would mean bigger carbs.
i didnt think that this would have been so simple.
what i meant was......if you take the carb off the banshee and stick it on ur blaster would it be worth it?
i mean, if u had to rejet and were having pilot issues and insted of buying pilots and mains and shit and u had acess to a banshee carb would it be worth it?
no, i don think that would work. My banshee carbs are small, i hope the blaster needs a bigger carb than that.
The shee has dual 26 mm's while the blaster has 1 26 mm. if you do change, it would be pointless, they are the same size
No
1 - 16 of 16 Posts
