I have an 01 warrior, I just had it bored and a new piston done I have rode it one time since then and now at wont run. I can't even get it to start. It turns over and will fire and then immediately die. I pulled the plug on it and it has no spark. I used a test light and the wires out of the stator are putting out power. I am not good with wiring. I used a meter and the stator is putting out 12.36 when turning over and one of the other plugs is bouncing between 1 and 3 when turning over at the firing coil when turning over stays at 4 and out of the spark plug wire stays at 4 when its turning over what should i do other than set it on fire lol. Any suggestions would be appreciated. Thanks
You have to test the stator for resistance(ohms) not power. There is a link to the manual at the top of this forum, it will explain what you have to do. If the stator is even a little out of specs, you will have to change it out.
