The bike ran fine, then made a clank noise and died, my cam chain and sprocket had came off, My old cam was toast, so I bought a replacement, installed it, put the head back on, now it won’t fire, not even a spudder with starting fluid, it has blue spark, just won’t kick over? Could my timing be off? Valves? The piston seems to be in good shape same for rings. I adjusted the valves, I’m still learning as I go. Any advice appreciated.
I pulled off the flywheel, made sure it was seated correctly, the key isn’t sheared. Rotated the engine to tdc, everything lines up, compression feels real light tho.
so if i was you my next step would be to double check the valve adjustment and do a compression test. will it fire with starting fluid
