I have a 350 warrior I was recently riding when it jus locked up out of nowhere now its taking off in first gear but wont move in 2nd gear and up whats wrong with it?..
can you provide a better description. it just takes off on its own? will it go into 2nd and up but wont move?
Yea it takes off in first when I let off the clutch jus fine but in 2nd gear and up it trys to move but seizes up n bogs down I was in 3rd gear whenever it jus locked up like the chain got stuck n it hasnt taken off in 2nd gear n up since reverse works fine as well
That sounds like a trans problem. Likely a bent or worn shift fork and it stuck in gear. You will need to split the cases and inspect the trans
