hey guys I have a warrior and it seems to make a knocking sound somewhere in the engine. I already checked the timing chain and it looks replaced it made a goudge in the sides. And I have already checked the valves. Intake seems to move a little bit but not that much. Exhaust is tight. I don't think it's the piston because it seems to have good compression. There's no lack of power pops a wheelie in first gear no problem does burnouts no problem. The noise seems to get louder as RPMs get higher. You can hear it when it's idling
Did you check the timing chain tensioner too?
