Hey guys, I just got a 98 warrior for cheap, come to find out the engine is locked up.the guy that sold it to me said it needs a starter. So far I have tested the starter, it’s fine.I took the spark plug out, put a wrench on the crank shaft bolt and it moved a little then got stuck…☹ went to check the oil filter for metal shavings and there wasn’t even a filter in there. So I plan on going through the engine and getting this turd back in action, but I’d like a little advice before I get too far into it.. first things first I’m buying a manual then plan on taking the head and jug off to see the condition of the top end most likely that’s smoked is there any recommendations on which parts to go with? Obviously I’d like to save a few bucks but I’d like to get quality parts. Also I’ve never been into the bottom end so once I have the jug off and can see the connecting rod how will I know if I will need to tear into that and again is there any good recommendations on a rebuild kit? There’s so many online idk what’s quality. I regret getting rid of my 01 it ran flawlessly now I’ve got my hands ful with a busted machine. Thank you In advance
