i have a 1987 warrior 350 with about 7 hours on engine rebuild. (rebuild was done by previous owner)
the quad ran fine but had a ticking rocker, it was the exhaust side and the only way to get it to stop ticking was to tighten it a little over spec.
i rode for about 3 hours straight and while running wide open in 6th on a paved road it sputtered a couple times and died like the ignition was cut off.
i got it home and turns out the exhuast side rocker is almost siezed on its shaft to the point where it takes a pry bar to move it up and down. (it was holding the valve 1/4 of the way down until i pryed it up) the valve is also bent from it hitting the piston. the piston is fine.
what could have caused this? when i removed the cam from the head the head was completely filled with oil so wouldnt think it would be an oil issue- also the intake rocker and shaft are in perfect condition.
could the overtightened valve lash have caused this? stretched timing chain? timing off/timing jumped a tooth?
i purchased a good used ebay head, i am going to install a stage 2 hotcam, and a new cam chain. and make sure the valve lash is perfectly within spec. will i be a-okay then?
i just want to know what could have caused it before i put all these parts in and it happens again.
thank you very much for helping me as i am new to the forum.
