Hello, I recently purchased a 98 warrior as a project. The motor was locked up so I took it all apart, new crank, new piston, new clutch etc.. transmission goes through all the gears and everything seems to be working, except when in gear the quad acts like it’s in neutral. I can roll the quad around.. I have been searching this problem and a lot of people say it’s the reverse lever but mine is completely engaged in the forward position. Has anyone else experienced this issue or knows a solution? I’ve noticed the clutch lever is sloppy and maybe the clutch rod in the cover isn’t in the proper location..? I’ll have to double check that. Also the wiring is a mess but Ill addressing that once I know the motor is in good condition. Thank you
