starts and idles fine but when I try to give it gas it blows back out of carb and dies but starts right backend will isle all day
most likely a cracked intake boot. check for other vacuum leaks and check the valves but i am 99 percent sure its the boot
I would agree with cory for the cracked boot as well. Also if you're carb is not clean it may cause a similar issue. I had the same problem and was not fixed until I ultimately had to replace the carb itself. Try inspecting the boot and if you do not see anything try and clean the carb really thorough and see what that gets you.
Hey guys im new here and not to sure where to ask this but I have a 2002 warrior 350 and I was just out riding and for some reason when I hit the throttle a lilbit itÂ*sputters but then I give it more gas and she kicks up and goes like there's nothing wrong.
So I went home and pulled the clutch in and it started to idle high so I put it in neutral and it idled high for a sec and then it went to a low idle and was almost dieingÂ*
Any thoughtsÂ*
i am assuming you mean pulled the clutch lever? not removed the clutch. check you intake boot for cracks, make sure your throttle cable is good. make sure your gas is new and clean. if none of that works clean your carb
Yes I agree that issue sounds like with the riding you done you've vibrated the throttle cable loose probably just need to check an re-adjust your cable
