Question: can you fit a warrior 350 piston in to a big bear 400 "2003"🤔 both have 83mm bore the, pin are both 19mm the same all i can see with out having them in front of me is the big bear piston has a dish on the crown where the warrior is a flat top what i cannot work out is the pin to crown height. The reason i would like to use the 350 piston is 1: opens up a lot of buying options and 2: a nice increase of compression
keep safe
best regards
cliff e
down under
I can’t answer whether it’ll work or not but keep in mind that if you run compression too high, you’ll run into not being able to run pump gas anymore.
Also you may need the big vote for valve clearance.
