i dont have the kit, but from what i have herd about vitos i wouldnet recomned it. also why would he trade a 240 cylinder for just a ported cylinder. unless the cylinder deosnt work good.
Actually the Vito's 240 kit is not the same sleeve as you can get from LA Sleeve, the vito's sleeve is designed for vitos, it has 2 extra exhaust ports, and the ports are opened a little more than a standard 240 sleeve, it is fitted into a new aluminum casting to vitos specs, the thing that hurts the performance of the vitos 240 is if you ever use just a standard 240 piston the port timings will be off, vitos fits their kit with their spec piston which has a cutout on the exhaust side to improve exhaust timing and the intake ports are raised to do the same for the intake, if you are going to port a vitos cylinder you CANNOT use their 240 piston, you will need to get a standard 240 piston or the timings will be too high and kill the bottom end power.lowriderb said:just a vito's 240 kit is a stock port sleeve pressed in for the bigger bore..
you can get it ported and it will make a bigger difference.. the way they are set up from vito's has stock port timings so they will suck..
the 240 sleeves are the same that everyone gets just porting after is what makes it worth while..
Eat at Joe's Dinner!!! :nod:lowriderb said:next is a commercial plug..
lol...175..porting cost more than that..ShifT714 said:so you guys are saying not to get it unless i wanna spend another 125 for port and polish and everything and then another 75 for another 240 piston or what?? thanks for all the advice..
Blasterkid13 said:lol...175..porting cost more than that..
quote]
not for me...guy named Eric Gorr that Yam21 hooked me up with did mine for 100 bucks cuz he didnt have to do a head mod, with the head mod(mill, shave and polish) is 125... he worked with Weisco on alot of there big bore kits too....really nice guy
www.eric-gorr.com
What you talkin bout Willis :wtf:kartracer92 said:Marc's on here if he don't get hit for a plug he will help that what he does everyday for a living if he don't know nobody does
Jeff
don't buy it, you will gain maybe 2HP.raptorjess said:so lemme get this straight, i just bought a blown up blaster to play around with and i was looking into the vitos 240 kit also... so my question is.. is it not worth a shit or what??????
well what do you guys think is a better deal/more competive motor then. ive had blasters before but never got into the motor, this one is the fun toy so id like to go a little extreme with this one. so tell me what you guys think is the best 240 or other size out.IMO.......there are better 240's availible at a competetive price.
