Sparks Racing sells a tps block-off sensor. How does it work? How can it re-map CDI for performance? I have a GYTR performance CDI installed as off right now. Can it help any?
Are you referring to the Throttle Position Sensor Bypass Plug?
There is no advantage to using one. The stock and most aftermarket CDI's have 3d maps in them, and what happens is when you use one of those plugs it tells the cdi that you are at wide open throttle all the time, and so it runs the WOT map. So there is absolutely no gains, you want the cdi to adjust the timing based on throttle position.
