1 - 9 of 9 Posts
Confused on how to adjust the shocks. The adjustment on the rezzie does what?? I know the bottom one says "tension" so thats self explanatory. But Im not sure wnat the rezzie one does. Thanks for the help. :tup:
The rezzie adjustment is the compression, clockwise for stiffer, counter
c-wise for softer.
The bottom is the rebound adjustment.
Warrior03 said:
Would anyone be able to tell me what rebound, preload, and compression do? Thanx!
Rebound - How fast the shock returns to its normal position after it's compressed.
preload - How stiff the spring is set at. With ZPS shocks you can set your ride hieght this way.
compression -How easily or hard the shock compresses when you hit bumps, jump, etc.
Discussion Starter · #7 ·
Good Info bro :tup: :tup: :tup:
1 - 9 of 9 Posts
