i need a higher rpm rev box for drag racing....what is a good one for the money....all i need is the rev limit to be like 10000 or higher
correct me if im wrong but they can be custom programmed, and honestly the raptor makes the majority of its power before 10K
unless you have a very built motor, the power at 10k isnt going to be all that great... :tdown:
He's running a stage 1 hotcam, he isnt even making power at 9k now. Upgrade the cam and porting a few notches and then you can worry about a higher rev limit.
The dyna does offer power gains on more than just top end, and would be the way to go regardless.
I dont know of any cams that make power above 9000rpm other than the Craycraft or x14. There may be some other custom ginds out there also.It takes a BUNCH believe me to make high rpm power.
