Hey guys, I have a few little surface rust spots on my frame here and there. How do I remove them? And once I do how can I touch up the little spots that I fix?
Sand them down a little bit and then throw some primer on there and then let it sit. And you can buy spray paint from PJ1 and it should match your frame and just give it a couple coats.
Just try medium grit and then go to a fine. Use it dry, shouldnt need to be wet.
