After just having installed a +2 Sparks Avenger swingarm and new Works Stadium rear shock I find out that I might need a different rear shock linkage.
Is there a difference between the 01 to 02 and up? Are the 02--05 smaller in width where the shock mounts to the link? Is the 01 better or the 02 and up?
The 01 linkage is cast, (forged?), aluminum and the 03-up is steel. I think the 02 are the same as the 03 and newer ones but I'm not positive about that.
No sure about the diminsions though.
When you order your shock you have to tell them if you have an '01 or an '02 and later. They take different width shock bushings. Just call Works and get the correct bushings.
