1 - 8 of 8 Posts
Im having problems with my rear brake. Every time I bleed the brakes it works well for about two rides. Then it just looses pressure and doesn't work until I bleed it again. Any ideas????
There is no brake fluid missing (check the rezzie all the time)
And the line doesn't seem to be cracked or broken???
I dont have that problem on my YFZ but I've heard people say that they needed a master cylinder rebuild kit when it happened to them. I guess you should contact your dealer and ask them about it.
Discussion Starter · #4 ·
EX 80 said:
Sounds like the same thing as mine. I bleed it, its tight for a ride. Then its soft. I mean i can still lock them up, but its not as tight.
Yea same here except they get so bad that they dont work at all! I'm going to look into the rebuild kit.
Sounds like you have air in the line, I know you said you have bled them, but there could still be some air in there.
Discussion Starter · #7 ·
The weird part is that I bleed the damn thing every weekend and it regains pressure. Then eventually, slowly the brakes starts to soften up and fail. I ordered the rezzie rebuilt kit, I'll let you guys know if it works. :whatever:
replace..not rebuild the rear brake master cylinder...i did so with a honda one and works great now....i am thinking of going a different route in the future..will let u know later
1 - 8 of 8 Posts
