I am looking for pictures of blaster with different size tire combinations. Mainly I would like to see blaster with 22 and 21 in front tires and 20 and 22 in rear tires for comparison. If you post a pic could you please state what size tires it has. Thanks
here are 22"s front and back
How do you like it? Is the ground clearence overwhelmingly better than if it had smaller tires. It looks alot better than I though it would. Thanks for the pic.
sorry bout the pictures. There just random ones i found and it shows the tires the best :shrug:
stock front.. i think 21..and 18 rear
stock front and 20 rear
Depending where I am riding I switch between the 22"s and 20"s. The ground clearance is noticible, and really helps on the rocky, and rougher trails. (I still manage to kill skid plates :( ) The 20's work better on the smoother higher speed trails and do not require as much body english in the corners then the 22"s.
