Ok this is what ive got up for sale!
Used frame $300, YZ426 carb $350, Front calipers pair $70 each $40,
Fluidyne radiator (damaged on top mounts but repairable $150,
Seat $50, Stock front bumper $15, Aftermarket subframe (has small weld) $100, AC grab bar with #plate bracket $30, Air box with Uni filter $50, Gastank needs knob for petcock $20, Front master cylinder $35,
Rear mastr cylinder line (worn) and pedal $60, Oil tank $60, Stock header with DG X2 silencer $150, Engine (cam mod, heavy duty clutch springs, lighteed flywheel, WR 450 crank and piston, new stator,has a broken top motor mount) $1300, Burgard -1 3/4 swing arm tha needs to be welded where dogbone attaches $200, I also have little odds and ends so message if your looking for something specific. This is the first time i've ever had a YFZ so im open to best offers as my prices are from what ive found elsewhere. Thanks for looking
Now the Burgard swing arm had a 250r carrier bearing $75, Lonestar 2+4 axle $200, 250r hubs $40, Rotor and locknut $75, and 250r rear caliper $60
I have pics of everything so please anyquestions please ask.
