1 - 12 of 12 Posts
ok i have an issue with my spyder3.0 guys i need some help...... if i have it on the co2 andhave it cocked it will fire the single shot then wont re-cock......so any ideas what is going on with it??? its tickin me off cuz i gotta play in the next week and i dont wanna use my old gun when i have electronic spyder, ya know? so any ideas cuz i only recently got this gun
Maybee you need a new co2 tank. Or check your battery. When i first got my Em1 i always forgot about the battery lol.
o-rings check ur volecity... my 2k3 autococker did that and it weas the pressure.
Check pressure on tanks and o-rings like the other guys said, also make sure the battery is fully charge. My Imagine Full auto did wacky stuff like that when the battery was dieing
spyders are all very simple guns, just take it apart replace the o rings lube it up and you should be fine, or while its apart if you see and irregularity that could be your problem.
Yup, unless your Co2 tank is empty, then you need to take the gun apart and replace all the o-rings with new ones and lube it real good. Spyders are VERY simple, yet decent guns. I had mine apart all the time.
Discussion Starter · #12 ·
thanks guys..... the tank is full, fires my other guns fine..... thanks for the help ill take it apart tonight
1 - 12 of 12 Posts
