If the filter was plugged up? Would it get oil to the bleed screw on the head. Because mine gets oil to the bleed screw greatis the oil filter plugged? possibly a weak oil pump
Okay so i need to check the oil filter and oil screen on bottom motor. Could it be the cam that i put in it?? Because when i had old cam and rockers it was fine. Dont the oil come threw the cam to oil everything??not if it was plugged tight but if it was partially plugged that would reduce you oil pressure. and explain why it comes out the hole and not through the rockers. i think i remember that it has 2 one regular filter and then a pre filter o n the plug
