I was just wondering if anybody had any ideas. My 87' just has a SupperTrapp and a K&N filter in the airbox, Jetting unknown. Ran well b4 buddy ran it out of oil. Since then I have had crank rebuilt and cyc bored 1 over. After rebuild and warm up it instantly siezed the rocker arms and shafts ( no I didn't use molly grease :s96: ). I ended up getting another head off ebay and now it's all togther still no oil to head.
I have found no info on the direction of oil flow or how the system works -if it takes time for oil to reach head? or if there is supposed to be oil in the magnito/stator side of the engine? I'm use to working on 2-strokes.
The oil filter is in properly
The oil pump works I can use pullstart to crank and pump oil to the oil filter
I did not remove the oil pipe (maybe I should have inspected it?)
no oil comes from the bolt on the head
I'm sick of working on this quad and it has set for almost a yr now so any help is much appreciated.
TIA, Read on and Ride hard!
Scott []v[]
Scott []v[]
