So I have 2001 raptor 660 the reverse light blinks so in turned down the idle. Fixed that. Then it won't let me Rev past 1/4 throttle. Cuts out and stalls. Put a brand new carb on. Took the reverse switch connection cleaned it took all the dirt and grime away. Plugged the switch back in and still won't let me go past 1/4 throttle. It's driving me crazy. Please any help would be much appreciated.
Did you try to bypass the reverse switch?
Discussion Starter · #4 ·
Did not bypass the reverse switch. Turns out it only runs good when both carbs are working. The right side can was not getting fuel. The left side was. So I did alot of swapping around of carb parts and now it seems to be running good.
