didn't tighten the axle nut all the way or didn't tighten the set screw is two possibllities that come to mind. Either that or your bearings are shot.
Karnivore nailed it, I would say it would have to be on of those things. Try tightening the axle nut again and resetting the set screw and see if it moves again. The first time you may have just not gotten it all the way in (unless the Axle uses spacers for some reason).karnivore660r said:didn't tighten the axle nut all the way or didn't tighten the set screw is two possibllities that come to mind. Either that or your bearings are shot.
