I can't figure this out and am hoping you can give me some ideas. I have a bone stock 450, other than a K&N filter (no lid on the box), the baffling has been removed from the stock pipe, and I purchased and installed a GYTR Jet kit. It took me a while, but I think I have finally set the jetting right (170 main, 45 pilot, and #4 needle clip). The problem I have is that for some reason, my bike will start cutting out and loses almost all of its performance. As I continue to ride, the power will come back and then go away again. I also have discovered that if I turn it off and then back on again, my power is restored for a minute or two, but eventually cuts out again.
I try to reproduce the problem so that I can work on it, but it is intermittent and rears its ugly head at will. If you have any suggestions, I am all ears! :(
when this happens turn your lights on. I think you have an electrical problem. Try it and see if it works
