I have a 2001 raptor 660 that was doing ok for the first day of riding but on the second day it started to cut back in power at 3/4 to full throttle and sputter and I would get an increasing number of popping from the exhaust. and I also noticed that the snorkel on the lid to the airbox had what seemed like it was drenched in oil. And so I saw that the airbox had a lot of oil on the bottom of it. I lowered the jet size and adjusted the needle clip to make it leaner thinking maybe it was rich but I still got power loss at full throttle and the cutting back didn't really stop. I noticed that it happened sort of slowly like I started getting some popping than I felt it cutting back and sputtering and it just got worse over the day.
most likely over full on the oil. normally on yamaha you check the oil by starting the machine and running it for 5 minutes. shut it off for 5 and then put the dipstick in up to the thread but dont screw it in. if that is how you checked it, great. if not you likely over filled it. if that is how you checked it and now its over full you probably have a carb issue and are dumping fuel into the crank case or you blew a head gasket and are pumping coolant into the case either way you would explain oil in the case. rings would have to be super loose to get that much oil in the box. if its dumping fuel check your float height. go back to the original jetting
I have an 05 raptor 660r se that backfires and bogs really badly it kinda idles very not very well though and when I give it throttle it backfires badly and. Sputters then dies and when I hold the clutch in and give it throttle It doesn't backfire and sputter as badly??? I just put super clean gas into it so oh and another thing to add on to that when I turn the key the reverse light comes on and stays on even when in gear so please help me I heard it could be the rev limiter any help will be DEEPLY appreciated thanks! shareit vidmate apk
If it idles poorly probably not the rev limiter. Pull and clean the carbs. Make sure the intakes boots are good and the carbs are well seated. If you are reving the machine above 1500 or so I. Neutral. That may be the issue with the light. It is a safety feature
oil up there is usually blowby bad rings
