1 - 1 of 1 Posts
· Registered
I'm so impressed with this I had to write a quick post. It's made of high density polyurethane. Fits tight with nothing more than a mallet hitting it softly. Conforms to the case exactly like a case saver should. There are no post or reviews on this item, that I can find, anywhere.
If you have had a chain come loose, and break your case, you know how vital this is.
I only had to trim the stock chain guard a little. It will bolt right back on. The case saver even comes with 2 longer bolts to fit the factory chain guard back on. You just eyeball the guard back on, trim the plastic, and it fits.
I'm running a 14t front sprocket(stock is 13). It has around .005 clearance at the closest point. A 15t sprocket would not fit without some shaving of the saver. Stock 13t and a 14t will fit, for sure.
Not a sponsor or getting anything for this. I seen no write ups on this. Some form of this should come factory on all chain driven atvs, dirtbikes.
It's about $45 from most places, and eBay.
Moose Racing 0920-0122
Crankset Automotive tire Wheel Gear Bicycle chain
Automotive tire Motor vehicle Automotive fuel system Automotive design Automotive exterior
Bicycle part Rim Automotive exterior Bumper Automotive wheel system
1 - 1 of 1 Posts
