Here's the steps to tighten the nuts from the service manual.
1.Tighten:
Nuts (rear axle) 1, 2
Nuts tightening steps:
NOTE:
Before tightening the nuts, apply the LOCTITE
® to the thread portion of the rear axle.
Finger tighten the inside nut 1 while checking
the ring gear engagement.
Tighten the inside nut with rear axle nut
wrench to specification while holding the rear
axle.
Hold the inside nut 1 and tighten the outside
nut 2 with rear axle nut wrench to specification.
Draw the line a on inside and outside nut.
Hold the outside nut 2 and tighten back the
inside nut 1 with rear axle nut wrench to
specification.
Measure the distance b between lines. If
distance b is less than 15 mm (0.59 in),
retighten back the inside nut.
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
Blue Traxx Forum
A forum community dedicated to Yamaha ATV owners and enthusiasts. Come join the discussion about performance, modifications, classifieds, racing, maintenance, and more! Open to Banshees, Raptors, Blasters, and others for recreational riding and racing.
