I have a beat up 87 Warrior....Replacing the stator and two pick ups, different color wires on each pick up...Which one goes closest to the engine when the cover is installed.? Thanks
its been a long time since i worked on an 87 but if i remember correctly the wires will really only let it lay one way and i am not sure it matters they are picking up the same magnet on the flywheel at the same time. it wont hurt it if it was wrong so use you best guess and if it wont start swap them. there are a bunch of pics if you do an image search, might help you decide
Thanks....I believe it's correct now....Some clown messed up a lot of stuff on this old turd , just waiting for a new CDI box...
