1 - 13 of 13 Posts
I AM RUNNING A DYNATEK REV BOX, CT PIPE, PRO DESIGN W/ K&N AIR FILTER AND 12 TOOTH FRONT SPROCKET. THE BIKE WILL ACCELERATE IN 4TH GEAR UP COMP HILL AT DUMONT BUT NOT WITH AUTHORITY. WILL A CAM HELP ME WITH THIS, IF SO WHAT GRIND AND COMPANY SHOULD I GO WITH. THANK YOU FOR ANY HELP.
The bigger the cam the less torque and more top-end you will see. A stage one Hot-cam is good to boost the midrange of the engine, and will allow the engine to rev a lil higher.. A stage two came will bring the Horsepower curve higher in the RPM's. BUT keep in mind a Stage 2 WILL NEED heavy duty springs, Hi comp. piston, and portwork to work to its full potential..
I HAVE SEEN PEOPLE TALK ABOUT HOT CAMS, WEB CAMS, CRAYCRAFT GRINDS, SPARKS CAMS, ETC... DO I JUST NEED TO START CALLING THESE MANUFACTURES OR BUILDERS FOR WHAT IS AVAILABLE? THE BIKE IS AN '04 AND NOT READY FOR A PISTON YET.
Once you start talking about grind specifics, you get into pretty technical calculations. Some of the cam builders make purpose specific grinds.. Hotcams and Webcams make a lil more generic grinds, Craycraft and the other builders may grind their cams prupose specific, drag racing etc..
If you are not gonna put a piston in, I would recommend a mild or stage one cam.. The biogger cams need more compression to compensate for the camshaft overlap, and the shorter duration..
HEY DIGGERZMOUND, DO YOU KNOW THE SPECS OF THE STOCK CAM. I AM TRYING TO COMPARE THE DIFFERENT RISE AND DURATION OF THE WEB CAM AND HOT CAM. I THINK THE STOCK #'S WOULD HELP ME WITH THIS COMPARISON. THANK YOU IF YOU CAN HELP.
Stock
Intake Lift - 5.74 mm (0.2260 in)
Exhaust Lift - 6.55 mm (0.2579 in)
Hot Cam
Stage 1
Intake - Lift 8.5 mm Duration 254 °
Exhaust - Lift 9.4 mm Duration 246 °
Stage 2
Intake - Lift 9.8 mm Duration 246 °
Exhaust - Lift 10.3 mm Duration 259 °
Powroll
MIdrange Grind
Lift .340”IN, .255” EX. Duration 242° IN, 245° EX
Race Grind ??
Alchohol grind ??
Web Cams
VALVE LIFT" DURATION GRIND #
.340/355 260/260 461/496
.340/355 270/279 696/697
.365/.365 275/275 736/737
.452/424 292/289 685
Megacycle
CAM # Valve Lift" DURATION
280-x2 .395/.372 243°-236° Mild Performance
280-x3 .452/.429 276°-274° All Around
280-x4 .452/.429 276°-274° All Around More lobe separation=Higher RPM
280-x11 .395/.372 243°-236° Mild Performace
280-x14 .452/.412 292°-294° Full race
Duncan Racing
Lift .452”..429” duration 276/274 degrees
Lift .452”/.412” duration 292/294 degrees
Duncan obviously uses Megacycle grinds....
Stock
Hot Cam
Stage 1
Stage 2
Did a quick online conversion thing to see if i could standardize these
Stock
I=.226
E=.258
HOT CAM
Stage 1
I=.335
E=.370
Stage 2
I=.386
E=.406
All numbers were rounded up
Hope this helps
Curious as to how much power the cam adds on a stock motor with a pipe and jet kit, anyone seen a dyno on a stage 1 bumpstick?
i have the stage 1 hotcam in my raptor w/ a pro circuit exhaust, gyt-r jet kit, and gytr filter w/ adaptor w/ snorkel removed.
it works great with just a stock motor, but will do even better w/ a piston and ported head.
if u just want the power w/out spending over 200 bucks, i would get the hotcam stage 1 .. its great for trails and all around riding.
I looked for a dyno sheet for one of these (couldn't find one), i'm sure they improve power, i'd just like to quantify how much
Turn your caps off!!!
Are the hotcams hard to install I do not want to take mine to the dealer I do all my service including my valve adjustments.. When I read the instructions on how to install a hot cam from hot cam it seemed a little technical.. I have worked on everything from cars to airplane motors.. I am sure I can handle it but just want your imputs as to the dificulty
Discussion Starter · #13 ·
Uhhh damn, I guess be careful what you wish for. That is alot of information. Thanks diggerzmound and ridingblind for trying to put it into english. Oh and Rap660R_04, let me say SORRY :razz: .
1 - 13 of 13 Posts
