1 - 10 of 10 Posts
Well I'm having trouble getting the hub off the spindle, anyone have any ideas? The bearings and everything seem good because it spins pretty freely.
This is for a blaster with drum brakes btw.
Lube it with some wd-40 and put a puller on it. I'm not sure of the correct name, but I have this thing with two 'arms' on it and a huge bolt in the middle. Put the arms around something and turn the bolt and it pulls it off. Or you could try a block of wood behind it and lightly tapping it with a hammer.
I would use a block of wood and hit it with a hammer. Or, you could put the wheel back on, and pull on that.
Get some good penetrating oil and let it sit a while, then use the wood block and hammer to free it. I tried this before a few times and it always works great for me :tup:
1 - 10 of 10 Posts
