so i was wondering the stock hp for a banshee. then with t6 racing pipes and a filter. and do you think put a filter right off each carb would help in performance at all? thx for the help
Around 6-8 is about right .....what changed on ur 97 was the usable power band or curve. I'm sure u noticed a change from low to mid response and a sharper throttle plus that great sound ... 6- 8 is still about a 20% increase in power so yes it will feel like a new machine. Add a adj timing plate with a couple of degree advance and 93 octane and a 12 --14 hp is what u will hit to complete ur package.....
I'm running the t6s with a couple mm bigger keihin carbs with v4 reeds and the box with no lid and a k&n. it all depends on what kinda riding you do hill climbing and woods riding even sandy terrain nothing touches it. I love the mid range power. If u have the means to do so get you a 1 tooth bigger and 1 tooth smaller front sprocket don't forget the casing saver you will be surprised what 1 tooth on the front sprocket will do.check your spark plug boots and connections from time to time never hurts.
A forum community dedicated to Yamaha ATV owners and enthusiasts. Come join the discussion about performance, modifications, classifieds, racing, maintenance, and more! Open to Banshees, Raptors, Blasters, and others for recreational riding and racing.
