I just got the HMF full system. i upgraded from their slip on. anyways, i need some help deciding on what, if any jets need to be changed. i have a k&n airfilter with lid and a hmf full system i also have the ncvq needle in there. im at 800ft. thanks for the help. i tried looking in the jetting sections but nobody else seemed to be in this postion.
thanks
What are you jetted at now? If your already on the 4th clip of the ncvq needle I would move up on the main jet. See if it runs good. Probably might need to play with the fuel screw but wont know that until you get it running/
i have a 170 main 45 pilot and i believe its is on clip 3 on the ncvq needle
Administrator
You should be fine...that's pretty close to what I run, and I'm at about the same elevation. :tup:
