Have a 1987 Yamaha Warrior I can't figure out how to get spark on it it's crazy I've replaced everything and I can only get one nice light blue Spark and then nothing let it sit for a minute you get one spark again and then nothing I could really use some pointers
ground the green wire that goes to the reverse shifter check the wires in the harness and if you just replaced good oem parts without testing them and used cheap ebay stuff to replace it suspect the new parts
Unfortunately yeah I bought cheap eBay parts $300 worth but I'll try that I feel like I'm out of options cuz I can't buy the CDI box nowhere
If you replaced ignition switch it will never run again. Put stock Yamaha one back on, it is the only one that will work. Ground the black/red wire from CDI to have spark. Unplug kill switch, they can go bad and can not be fully tested. All Yamaha ATV CDIS are available here. new cdi for yamaha
