Help remove steering stem bearing /retainer nut on 99warrior
252 Views 1 Reply 2 Participants Last post by  kylesyfz450
Restoring a warrior too to bottom on at the Last part of dissection before I take the frame for powder coating .
I need help on the method or the right tool or what is needed too remove the middle inner steering stem retainer nut in order too remove my lower bearing on my 99 warrior 350
I got the upper and lower rubber seal out and brass bushing fell out
Showing here a photo of what looks like a hexagon brass inner retainer nut that I don’t know if that’s the bearing or a threaded portion of the frame ?
If that is a retainer nut does the bearing press out the same side as the retainer or does it press out toward the ground
Who’s the expert on this 👍
Automotive tire Tire Wood Eyelash Tree
Automotive tire Wood Rim Motor vehicle Automotive wheel system
See less See more
2
Who’s the expert on this 👍 View attachment 6616
Looks to be the same as a banshee I bought a bolt & 2 nuts that fit that . Jamb the 2 nuts together on bolt then use head of bolt & then threaded it out like that . The bearing will then come out after you screw that out . Hope that helps.
