if anyone wants to give me some instructions on putting a aftermarket axle on that would be great.My first time doing anything with an axle :???:
Take the 2 allen screws off that are on the big lock nut on the right side were the brake disc caliper is at.Make sure you got the right tools for the (2 Allen screws)take off the caliper and disc loosen up the big lock nuts at the you are going to need two wrenches adjustable( I used a pipe wrench and A Big adjustable wrench)than take off your hub at the end of the axle and slide it out from the chain sprokect side.Thats the way i did it if im wrong im sure somebody eill correct me here :tup: than just go backwards to asseblr it back to together with the parts provided with your new aftermarket axle.
