HELP NEEDED QUICK!!!!!!!!!!!!!SPARK PLUG ReMOVAL!!!!!!
17K views 4 replies 5 participants last post by  THEMOOSE
The Raptor also requires a deeper than normal socket, Motion Pro makes a nice spark plug socket I keep the Motion Pro in my tool box & leave the stamped one in the quad.
make sure you blow out around the plug before you remove it, if the seal was loose all kinds of crap can get in there & will fall in to the engine when you remove it. Make sure you get the seal back in correctly, it'll only fit 1 way.
when you put the new plug in put a dab of anti-seize on the threads.
