I ordered New carb,intake boot.before I put the new carb on it ran good .After putting on the new carb it fired up for just a minute then died.it keeps doing this and will not start.so u put the old carb back on still same thing.u put a pen spring on the acceleration pump pin.the first issue was the safety switch for the parking brake.........it cranks then dies .I can't think of anything else.it cranks ideals for a second then just dies like it's out of gas with new and old carb and New intake boot
2003 Raptor 660, .05 over bore, FMF slip on, Fullflight +2 A Arms
Make sure fuel is getting to the carbs, and make sure your fuel is on. Also, if the machine has been sitting, it probably wouldn't hurt to throw a little fresh 93 in there with a mix of any fuel additives you prefer. I use seafoam.
